Hi !
I'm having a problem while writing into a template file, see image of log error. In fact, out of about 20 translations, there is one with this problem arising while writing data. Can someone tell me if it's a bug with FME or about my parameters ? I doubt the problem with my parameters, because very often it works well while wring the Excel file.
Please help !
Thank you.
