TCL startup script fails on server (runs on desktop)
  • Oct 17, 2017 10:52 PM UTC
  • 181 views
dfresh
probably a permission issue, but not sure what it is failing. I continuously get this error.
2017-10-18 10:22:55 A SAFE license service was detected running on port ##### on server ABC (##.##.##.##) and offering FME licenses. Please ensure that fmelicensingassistant is configured to use it (enter either 'ABC' or 'ABC:#####' for the Server Name), and that it has sufficient licenses for you.
the startup script is
lappend sysString $FME_MacroValues(FME_HOME_UNIX)/fme;
lappend sysString {Generate};
lappend sysString {GEODATABASE_FILE};
lappend sysString {NULL};
lappend sysString $FME_MacroValues(SRC_GDB);
lappend sysString $env(TEMP)/temp.fme;
lappend sysString {--RESOLVE_DOMAINS};
lappend sysString {YES};
lappend sysString {2>@1};
eval exec $sysString;
Any thoughts? I am actively working on this, so will hopefully have it resolved.
Best answer by daveatsafe
Hi @dfresh,
That TCL code starts a command line FME to generate a mapping file, from which the domain information is read. This works fine on Desktop, but in the Server environment, the FME Engines are constantly running, and have used up all the available licenses. So the command line FME will always fail with a licensing error.
This was written quite a few years ago, and newer versions of FME have another way to get the domain information. The FeatureReader transformer can be set to output only a Schema feature, and the schema for Geodatabases include the domain definitions, if the reader setting Resolve Domains is enabled.
I would recommend using the FeatureReader instead the TCL code.
dfresh
  • Oct 17, 2017 11:33 PM UTC
I solved it, I needed ArcGIS installed on the server to read the GEODATABASE_FILE...
UPDATE - this did not solve it, it only allowed me to login to the server and run a local .FMW.
dfresh
  • Oct 18, 2017 4:26 PM UTC
The server is licensed, the fme local desktop version is licensed and able to run, not sure why its causing this issue @DaveAtSafe
daveatsafe
Forum|alt.badge.img+24
  • Oct 18, 2017 8:13 PM UTC
Hi @dfresh,
dfresh
  • Oct 19, 2017 4:26 PM UTC
Hi @dfresh,
Thanks @DaveAtSafe you are the best, I owe you a beer.
