TCL script adding folder to destination directory NOT included in original FME Workspace?
  • Sep 13, 2019 7:03 PM UTC
  • 59 views
I have a simple FME Workspace which runs perfectly. However, creating then running the associated TCL file (via .BAT file) is for some reason adding the source-directory parent-folder to the destination directory. This does not happen when running the .fmw alone.
FMW Example: Reader Source - "C:/Temp/SourceData/" ; Writer Destination - "C:/Temp/OutputData/" ; Run TCL - adds "SourceData/", thus saving writer results to "C:/Temp/OutputData/SourceData/". Note: the TCL runs successfully, however the results are being written into this subfolder.
I can only guess that the TCL file is including code which adds the parent folder...? (The workspace is not doing this.) Any ideas? Thank you!
fmelizard
Forum|alt.badge.img+22
  • Sep 13, 2019 9:22 PM UTC
Hi @avocado Please send your workspace, batch and Tcl scripts, and log files to us via https://www.safe.com/support/report-a-problem/ Thanks!
