Target attribute containing a colon with TestFilter
I have loaded some features from an Open Street Map file (.OSM). Some features have the attribute "oneway" and "oneway:bicycle". I'm a able to create a test clause targeting "oneway". When I try to do the same for "oneway:bicycle", I get an error: "Specified attribute does not exist" (see image at the end).
This causes the software to show a warning before running the workflow. Strangely enough, the filter is applied perfectly fine! Am I doing something wrong? Or can the warning maybe be a bug?
fme-issuefme-issue2
Best answer by ebygomm
Is the attribute actually exposed? Just because it is available in the feature information window doesn't mean it's available on the canvas. It does exist, hence why your workflow still runs, despite the warning, but if it's not exposed you can't reference it in a transformer
dustin
Forum|alt.badge.img+30
  • February 8, 2023
Try exposing oneway:bicycle prior to your TestFilter using an AttributeExposer.
Forum|alt.badge.img+32
  • February 8, 2023
  • February 8, 2023
That did the trick, thank you!
  • February 8, 2023
Adding the AttributeExposer did indeed work, thank you!
