Taking data from a point object into a Polygons
  • September 9, 2016
  • 71 views
Any help on the problem below would be greatly appreciated:
I have two MapInfo layers, one is points and one is polygons.
Multiple point features may exist within one polygon.
I have data in a column in the points layer that I want to copy into the a column in the polygon layer. As there maybe multiple points within a polygon I want to concatenate the data from the multiple point features that are within that polygon into one column in the polygon layer, thus losing no tabular data from points to polygon.
Thanks in advance.
Best answer by owen
Hi Jeff, I would use the spatial relator > listsorter > list duplicate remover (optional) and then list concatenator. Owen
owen
  • September 9, 2016
  • September 12, 2016
Owen, thank you, you have saved my life! This works perfect.
