Table creation parameter per feature like fme_db_operation
helmoetz
Forum|alt.badge.img+14
Hi, is it possible to control the table creation parameter from features when using a database writer? Like one can control the feature creation, removal or updating using an attribute fme_db_operation on the feature. I'm looking for some parameter fme_db_table_handling or so, but it does not seem to be documented?
nielsgerrits
Forum|alt.badge.img+55
You can create a Parameter to do this. You can just generate that one yourself if needed by clicking the arrow next to it, User Parameter, Create User Parameter.
I don't know of an attribute which does this, like fme_db_operation.
helmoetz
  • August 9, 2021
Hi @nielsgerrits​ Thanks, I thought I remembered from an old database training that there was such an attribute. If I come across it, I will mention it here.
geomancer
Forum|alt.badge.img+51
  • August 9, 2021
Hi @Helmoet de Zwijger​, there are some mentions of an attribute 'fme_table_handling' in the knowledge base: here and here.
In Feature Type 'xxxxxx''fme_table_handling' has invalid value 'CREATE_IF_MISSING'. Possible values include: 'CREATE_IF_MISSING''DROP_CREATE''USE_EXISTING'
This may well be the attribute you are looking for. Not sure whether it still works though...
nielsgerrits
Good find!
helmoetz
  • August 13, 2021
O wow @geomancer​ , you found it... It is even still documented like here. However, it seems it does not work anymore by assigning it a value from, say, an AttributeCreator. I presume that is meant to be? It even appears in the .fmw scripts (line 12):
#!     <FEAT_ATTRIBUTE ATTR_NAME="downloadurl" ATTR_TYPE="char(255)" ATTR_HAS_PORT="true" ATTR_VALUE=""/>
#!     <FEAT_ATTRIBUTE ATTR_NAME="localfile" ATTR_TYPE="char(255)" ATTR_HAS_PORT="true" ATTR_VALUE=""/>
#!     <DEFLINE_PARM PARM_NAME="fme_advanced_group" PARM_VALUE="FME_DISCLOSURE_OPEN"/>
#!     <DEFLINE_PARM PARM_NAME="fme_configuration_common_group" PARM_VALUE=""/>
#!     <DEFLINE_PARM PARM_NAME="fme_configuration_group" PARM_VALUE=""/>
#!     <DEFLINE_PARM PARM_NAME="fme_feature_operation" PARM_VALUE="INSERT"/>
#!     <DEFLINE_PARM PARM_NAME="fme_match_columns" PARM_VALUE="<Unused>"/>
#!     <DEFLINE_PARM PARM_NAME="fme_selection_group" PARM_VALUE=""/>
#!     <DEFLINE_PARM PARM_NAME="fme_selection_method" PARM_VALUE="<Unused>"/>
#!     <DEFLINE_PARM PARM_NAME="fme_spatial_group" PARM_VALUE=""/>
#!     <DEFLINE_PARM PARM_NAME="fme_table_creation_group" PARM_VALUE="FME_DISCLOSURE_CLOSED"/>
#!     <DEFLINE_PARM PARM_NAME="fme_table_handling" PARM_VALUE="CREATE_IF_MISSING"/>
#!     <DEFLINE_PARM PARM_NAME="fme_update_geometry" PARM_VALUE="<Unused>"/>
#!     <DEFLINE_PARM PARM_NAME="fme_where_builder_clause" PARM_VALUE="<Unused>"/>
#!     <DEFLINE_PARM PARM_NAME="postgis_allow_serial_writing" PARM_VALUE="NO"/>
#!     <DEFLINE_PARM PARM_NAME="postgis_create_gist_index" PARM_VALUE="YES"/>
#!     <DEFLINE_PARM PARM_NAME="postgis_spatial_column" PARM_VALUE="geom"/>
#!     <DEFLINE_PARM PARM_NAME="postgis_spatial_column_type" PARM_VALUE="geometry"/>
#!     <DEFLINE_PARM PARM_NAME="postgis_srid" PARM_VALUE="28992"/>
#!     <DEFLINE_PARM PARM_NAME="postgis_vacuum_analyze" PARM_VALUE="NO"/>
#! </FEATURE_TYPE>
#! </FEATURE_TYPES>
Or am I expecting irrelevant things @Ryan Cragg​ ?
geomancer
  • August 13, 2021
Hi @Helmoet de Zwijger​ , it's always nice to help an old friend.
As you say, the parameter 'fme_table_handling' still exists, and is still in use in the fmw files.
Another example (line 8):
ORACLE_NONSPATIAL_1_DEF <table name>
	oracle_create_table ""
	oracle_drop_table ""
	oracle_table_writer_mode ""
	oracle_update_key_columns ""
	oracle_truncate_table ""
	fme_feature_operation INSERT
	fme_table_handling DROP_CREATE
	<field definitions>
I hope someone from Safe can answer your questions!
danminneyatsaf
Forum|alt.badge.img+12
Hi @Helmoet de Zwijger​,  this is an interesting one! I discussed the issue with my team and it sounds like the fme_table_handling parameter must be set before the workspace is run.
Some possible ways to get around this could be to try using a parameter fetcher or a workspace runner and set the parameter value before the workspace is run. Let me know how it goes, always here to help!
