table content transformation
  • August 11, 2016
  • 14 replies
  • 193 views
Hello All,
Is there a way in FME to transform the CSV table here below:
into this:
Thanks!
Best answer by fmelizard
Interesting question. When I looked at this I was reminded of the AttributePivoter, which made a debut in FME a couple years back. It does exactly what is desired -- it can collapse a set of rows into a single one, and add new columns (attributes) whose name comes from one older column and whose value is a statistical calculation of another.
I've attached a template that does this. Note -- this only works if the "value"s are numeric. I believe this is so in the input, despite seeing a comma as the decimal separator. If not, it is easy to string substitute a , with a . , do the pivot, and then substitute back again.
It is a bit tricky to set this up and you do need to set your writer to be in "dynamic" mode, but check all the settings in the attached and they should get you pointed the right way.
pivot.fmwt
erik_jan
Forum|alt.badge.img+26
  • August 11, 2016
Yes:
Use the AttributeCreator (Name @Value(TYPE) and Value @Value(VALUE)) to create a new attribute with the name mentioned in the TYPE attribute.
Then use an Aggregator (group by ID, FROM, TO, PROFILE) to merge into one line.
Then create the output with all desired attributes.
  • August 12, 2016
Yes:
Thanks so far. In the last step, what do you mean "create the output"? You mean in the Writer or within the Aggregator?
  • August 12, 2016
Yes:
And will AttributeCreator (Name @Value(TYPE)) create as much new attributes as in the TYPE field? I have tried that but that doesn't work.
  • August 13, 2016
The AttributeCreater with this setting will definitely create a new attribute which has a name equal to the value of 'TYPE', but Workbench will not expose the name automatically. Try using the Logger to check if the attribute will be created.
You can use the AttributeExposer to expose the new attributes if necessary.
fmelizard
Forum|alt.badge.img+22
  • August 13, 2016
pivot.fmwt
  • August 17, 2016
pivot.fmwt
Thank you!
I noticed a writer is necessary to get the new attributes created by AttributePivot. Since I still need the results for further process, but no normal transformer can be used directly after AttributePivtor because they cannot get those new attributes, right?
  • August 17, 2016
This will create a new attribute "@Value(TYPE)"
  • August 17, 2016
Thank you!
@zhoudonghan, if you need to handle the new attributes with subsequent transformers, you can expose those names using the AttributeExposer.
  • August 17, 2016
How did you enter the new attribute name? Try setting it from the menu button: Attribute Value > TYPE.
  • August 17, 2016
@takashi, yes, I did like what you showed here. It creates new attribute "@Value(TYPE)"
  • August 17, 2016
@takashi, thank you. But I saw that I need to type those attribute names instead of getting them automatically, right?,
  • August 17, 2016
yup, unfortunately you need to type the attribute names manually.
  • August 17, 2016
Perhaps you are looking at the attribute name on the Workbench interface. Indeed the interface shows "@Value(TYPE)", but FME creates desired attributes internally. Try checking with the Logger.
gio
Forum|alt.badge.img+15
  • August 17, 2016
Manually mutate New attribute to @Value(@Value(TYPE))
This will create the attribute name by its content.
