SystemCaller to call on a different system?
  • Feb 23, 2018 4:42 PM UTC
  • 102 views
Hello,
Is there any way to use SystemCaller to call on the terminal of a remote server?
We have FME server hosted on a computer. We have another program hosted on a Google virtual machine. It is a linux based machine and I run a couple of simple commands there. I would like to be able to do that using FME Server.
Thanks.
Best answer by fmelizard
Hi @fariyafarhad,
You might be able to write a batch script which calls Putty. I found this thread on this topic which might be of use. I'm not sure that you could directly use the SystemCaller on a remote machine.
Interesting idea though!
fmelizard
Forum|alt.badge.img+22
  • Feb 23, 2018 6:25 PM UTC
Hi @fariyafarhad,
Hi @fariyafarhad,
Hello @MattAtSafe thank you for your response. I had the opportunity to test this out today and it works. I actually found another thread that helped me with my task a bit more. The link is below for future reference. Thank you for guiding me in the right direction :)
Link
