SystemCaller error
  • March 20, 2022
  • 7 replies
  • 69 views
ienesaglam60
Forum|alt.badge.img+3
I have one line command. This command works manually in cmd command windows. When I try with fme systemcaller it does not work. What could be the problem? Fme version 2021.1.1.0 build 21619
example:
xcopy "@Value(png_source)" "@Value(png_dest)*"
xcopy "C:\\gml\\F-12696263-A.png" "C:\\gml\\gml\\F-23-A.png*"
ienesaglam60
  • March 20, 2022
@Hans van der Maarel​
danilo_fme
Forum|alt.badge.img+53
  • March 20, 2022
Hi @ienesaglam60​
I recreated your case here and it was worked.
Workspace_SystemCaller
As you can see on image bellow, the transformer AttributeManager I created the map of Source and Destination.
Map
The transformer SystemCaller worked fine to paste the image to destination folder.
Thanks in Advance,
Danilo
ienesaglam60
  • March 21, 2022
Hi @ienesaglam60​
Map
Thanks in Advance,
Danilo
The destination path also contains the filename. Currently this is not working. What should I do?
danilo_fme
  • March 21, 2022
Ok.
It just use:
copy "@Value(png_source)*" "@Value(png_dest)*"
ienesaglam60
  • March 21, 2022
Don't work . the log file
SystemCaller_3: Executing `xcopy "C:\\Users\\Enes Sağlam\\Desktop\\F-12696263-A\\GML\\F-12696263-A.png" "C:\\Users\\Enes Sağlam\\Desktop\\F-21444629-A\\GML\\F-21444629-A.png*"'
0 File(s) copied
SystemCaller_3: Failed to Execute `xcopy "C:\\Users\\Enes Sağlam\\Desktop\\F-12696263-A\\GML\\F-12696263-A.png" "C:\\Users\\Enes Sağlam\\Desktop\\F-21444629-A\\GML\\F-21444629-A.png*"'
danilo_fme
  • March 21, 2022
Please, elimine X. Let it just copy
Exeample:
ienesaglam60
  • March 24, 2022
It doesn't work.
