System Caller process and release
  • Oct 19, 2022 5:38 AM UTC
  • 364 views
deanhowell
Forum|alt.badge.img+24
I have a workbench that has around 7000 features and I want to run a system caller on each to produce an image (png) output, convert that image to a blob, store the blob in the database and delete the file.
At present the System Caller is processing all features before it moves on.
Is it possible to have the system caller run for an individual feature and continue on with the process?
nielsgerrits
Forum|alt.badge.img+67
maybe if you put it in a custom transformer with group by id?
nielsgerrits
Hej @deanhowell​ I could not reproduce the behavior you described (the systemcaller being a blocking transformer) in 2021.2. You can create a group by setting for a transformer , dropping it in a custom transformer and set parameters for Group By and Group By Mode, but I wonder if this solves your issue.
deanhowell
  • Oct 19, 2022 9:06 AM UTC
Thanks @nielsgerrits​ unfortunately we are using 2019.2 but I did get a solution where I added a sorter and used the group by option as you suggested. I will post my solution shortly. Thanks for your assistance ​
deanhowell
  • Oct 19, 2022 10:26 PM UTC
In the end it just needed the sorter transformer before the system caller to process it one by one.
imageThanks @nielsgerrits​ for great help as always
