sum
  • Jul 3, 2019 12:35 PM UTC
  • 74 views
terezia86
HI,
I need to get a sum of attributes.
For Example:
Gew: 45
Priv: 388
I need to get : Result 433
Which transformer to use?
Best answer by nielsgerrits
Presumed that the data is on one row / feature, you can use an ExpressionEvaluator.
Or AttributeCreator / AttributeManager, but then you need to select "Open Arithmetic Editor..." to force it from string.
sum2018.fmwt
nielsgerrits
Forum|alt.badge.img+67
  • Jul 3, 2019 12:37 PM UTC
sum2018.fmwt
terezia86
  • Jul 3, 2019 12:39 PM UTC
sum2018.fmwt
which expression do I need to use in AttributeCreator?
nielsgerrits
Just drag or doubleclick the attributes.
