Suitable READER for LEICA Equipment data .....?
  • Aug 3, 2023 1:06 PM UTC
  • 6 replies
  • 208 views
vimva679
Forum|alt.badge.img+11
I would like to import the Control points from Leica TS10 into FME
https://leica-geosystems.com/en-gb/products/total-stations/manual-total-stations
I would like to import the Point cloud from Leica RTC360 into FME
https://leica-geosystems.com/en-gb/products/laser-scanners/scanners
WHAT KIND OF READER I use to read the data into FME , I didn't find any so if anyone is aware of ???
kailinatsafe
Forum|alt.badge.img+24
Hello @vimva679​, thanks for posting to the FME Community! You mention the Leica equipment produces point cloud data, are you able to pass along the exact file format or extension (eg. ".las", ".xyz")? Otherwise, I suggest we take a look at FME's Format Matrix (Filter by category: "LiDAR & Point Cloud").
If we do not offer a native Reader/Writer for the format you're looking to migrate, are you able to export to any other formats? Happy to help, Kailin.
vimva679
  • Sep 12, 2023 2:32 PM UTC
@kailinatsafe​ Hello plz i had to wait for survey team to pass me details of file format, please find the screenshot of point cloud
  1. RAW point cloud downloaded from LEICA RTC360 MicrosoftTeams-image
  2. Once we process using mySurvey (https://leica-geosystems.com/en-gb/products/laser-scanners/software/leica-cyclone/leica-cyclone-register-360) this is the final output
vimva679
No other format it could be exported as the point cloud could not be read
kailinatsafe
Hello @vimva679​, no worries at all! So it looks like the processed .scan files are saved as IFC and TEXT files? is that correct? If that is the case, FME does offer both IFC and TEXT File Readers! If you're new to working with IFC in FME, check out this Getting Started with BIM tutorial series! Happy to help, Kailin.
vimva679
  • Sep 12, 2023 3:50 PM UTC
@kailinatsafe​ SCAN file so am not sure if its text file . However i will send a small sample data. Please as its highly secured data , do let me know what email id to send. As i sent data to support@safe.com previously, so please let me know if you want me send at the same email id with your attention.
I cld send you pre and post data sample data for you to help.
kailinatsafe
Hello @vimva679​, unfortunately we've retired support@safe.com, are you able to resubmit the case using this online form? I'll keep my eyes open for the case. Many thanks, Kailin.
