Substract values results in string?
  • Apr 9, 2020 1:37 PM UTC
  • 73 views
smartman63
Hello,
I'm having trouble to substract 2 values. The source attributes (ontwerp & rekenk, yellow) are encoded utf. I convert them to 2 new attributes such as "@real32(@Value(rekenk))". (blue) Then I want to substract those numeric real values in "TEST" but that results in a string? (red)
Any ideas?
Best answer by ebygomm
You need to make sure that you are using the arithmetic editor not the text editor
Forum|alt.badge.img+54
  • Apr 9, 2020 1:45 PM UTC
  • Apr 9, 2020 2:22 PM UTC
Or simply wrap the whole expression up into a call to @Evaluate():
@Evaluate(@Value(NUM_REKEN)-@Value(NUM_ONTW))
smartman63
  • Apr 9, 2020 6:21 PM UTC
Wow, that looks pretty simple! I'll give it a try. Thnxs.
