Styling lines using the mapnik rasterizer
  • January 25, 2017
  • 144 views
femo
I have administrative boundaries as lines that I want to rasterize. One boundary pattern looks like this:
However, according to the type of boundary the number of dots and lines vary.
So far I have experimented with the "line pattern" symbolizer where I reference a png-file with the above pattern. The result, well, horrible:
The blue line illustrates the original vector line. I would like the line pattern to be more dense and less blurred! Well, tommorow I will try the symbolizer "line", maybe I need to "stack" different styles? No clue yet.
The following sceenshots shows what it should look like:
jdh
Forum|alt.badge.img+41
  • January 25, 2017
Have you considered using a regular line with a dash array?
Something like 5,2,1,2,1,2 should give you the pattern you want. The actual values will depend on the pixel resolution.
femo
  • February 1, 2017
Hi @jdh, th was the hint I needed! Thank you a lot.
