StringSearcher size limit?
  • Dec 11, 2018 3:16 PM UTC
  • 68 views
Hi
Is there a size limit for the "Search in"-string of the StringSearcher-Transformer?
Regards, Tobias
gio
Forum|alt.badge.img+15
  • Dec 11, 2018 4:28 PM UTC
@tobibruehlmeier
Is it not the same as the 1000 expressions limit (oracle sql) ?
Mostly solved by using an OR statement IN(..) OR IN (..) ..etc.
  • Dec 12, 2018 2:15 PM UTC
If you need to find a part that matches a regular expression from first N characters in an attribute value, the SubstringExtractor or the @Substring function can be used to create the value to be set to the Search In parameter.
