StringSearcher only returning the first number in the string
  • Jul 23, 2019 3:53 PM UTC
  • 86 views
dbryantgeo
Forum|alt.badge.img+7
I am reading the source file from an SFTP folder and storing it into an attribute for the purposes of later downloading the right file (as the folder read may contain various files).
I use a StringSearcher transformer twice, once to identify that the files that are an xlslx and again to try and identify the date that is contained in the filename. I'll later discard the older files and only read in and store data from the newest file.
The filenames are formatted like Test_Test_240519.xlslx but the logger/inspector suggests that only the first number is being returned in the destination attribute.
The regex is a simple /d. I have also tried [0-9].
We're currently on FME 2017.0.1.1 but will be upgrading shortly - maybe this is an old bug but it seems odd that I can't find anything about it online?
Best answer by ebygomm
If you want to return the digits in "Test_Test_240519.xlslx" the regex needs to be [0-9]+ or \\d+
Forum|alt.badge.img+54
  • Jul 23, 2019 4:41 PM UTC
dbryantgeo
  • Jul 25, 2019 10:10 AM UTC
@egomm thank you very much, regex is obviously not my strong suit.
