StringReplacer with Regex String via Feature Attribute
  • Oct 22, 2019 7:53 AM UTC
  • 12 replies
  • 219 views
I want to perform a Regex search in a string and I want to pass the regex pattern via a feature attribute. However, when I pass the regex pattern in the attribute and select it in the StringSearcher in the field "Contains Regular Expression", I get no match. When I enter the pattern manually in this field, the matching works.
How can I pass a regex pattern via an attribute?
Best answer by ebygomm
You need to add the regex to your feature, at the moment it is on a separate feature, the attributecreator needs to be added inline before the stringsearcher
  • Oct 22, 2019 8:13 AM UTC
Seems to work just fine with FME 2019.1:
My regex contains "\\d+" and as a result _first_match contains "123", as expected.
Can you perhaps post a minimal workspace that reproduces the issue.
  • Oct 22, 2019 8:18 AM UTC
Ok...
My pattern looks like this:
It has Umlaute (ä/ö/ü).
(EGRID)|(Gemeinde)|(Gebäudename)|(Gebäudeklasse)|(Objektname)|(Name des Gebäudes)|(Parzellennummer)
This is my StringSearcher.
I use FME 2018.1
  • Oct 22, 2019 8:34 AM UTC
Ok...
I use FME 2018.1
Does your text come line-by-line, or as a single block?
  • Oct 22, 2019 8:35 AM UTC
How can I determine this?
  • Oct 22, 2019 8:40 AM UTC
To ask differently, how many input features to the StringSearcher is there? A single one, or one input feature for each line of the text?
A sample workspace with sample values would be very helpful, so far I've been unable to find anything patently wrong with the StringSearcher in FME 2018.1, using your sample regex and text.
  • Oct 22, 2019 8:50 AM UTC
Ok, here it is: regex_pattern.fmw
Thanks a lot for your help!
Forum|alt.badge.img+54
  • Oct 22, 2019 8:52 AM UTC
  • Oct 22, 2019 8:56 AM UTC
Ah ok!
In the real workspace, this is not possible because the pattern is coming from a DB. I used a Feature Merger with 1:1 matching to get it in one feature.
Thanks again for your help!
  • Oct 22, 2019 8:59 AM UTC
Or it is possible to use a Feature Merger with 1:1 to merge two streams.
  • Oct 22, 2019 9:06 AM UTC
Yes, you can merge like that. If your pattern is coming from a database, i would add an inspector to the database reader and see what the pattern looks like. It may be an issue with the encoding.
  • Oct 22, 2019 9:07 AM UTC
Ok, thanks. In the meantime, it works! I get the separate strings from a database and then merge it in FME with an Aggregator. Fantastic!
