StringReplacer | Per mille
  • Sep 24, 2019 4:36 PM UTC
  • 78 views
I'm trying to replace the per mille sign ‰ to the other symbol with StringReplacer, but this function seems to not work for this particular character. As import file I use .txt-file.
Is it a known issue? Is there a workround for this problem?
I work with FME 2018.1
Forum|alt.badge.img+54
  • Sep 24, 2019 4:47 PM UTC
I can replace that character directly in the string replacer in 2018.1. You could try replace regex instead with the following value
\x{2030}
It may be something to do with the encoding in your text file.
  • Sep 25, 2019 9:11 AM UTC
Thank you for the hint!
Indeed, the problem was the encoding: I set the Tranformer AttributeEncoder (change to utf8) before the StringReplacer and it works perfectly!
