StringReplacer does not replace newline
  • Sep 4, 2025 9:22 AM UTC
  • 109 views
r_huesken
Forum|alt.badge.img+5
StringReplace does not do what I expect (version 2024.2.1.0)
Newlines are not replaced, can someone please point out what I'm doing wrong?
Best answer by ebygomm
Your regular expression isn’t correct
Your test string contains the actual text \n which is what your regex is matching
Try using \R
Forum|alt.badge.img+54
  • Sep 4, 2025 9:29 AM UTC
Try using \R
r_huesken
  • Sep 4, 2025 9:36 AM UTC
Thanks, this helped. Maybe add this tip in the Help for the transformer?
