StringReplacer - different behavior after update from FME Server 2021 to 2022
  • Sep 23, 2022 1:40 PM UTC
  • 8 replies
  • 134 views
Ich use a String Replacer that cleans all values from "??".
Mode: Replace Text
Case Sensitive No
Text to replace ??
Replacement Text
(Replacement Text is empty as just I want to delete all ??)
This Workt fine in FME Server 2021
on FME Server 2022 I get an Error:
"StringReplacer_4 (StringReplacerFactory): Internal error: Failed to build ICU replace pattern. String was '"Große Mohreng. 9, 1020 ??, Österreich"', replacement pattern was '??' "
  • Sep 24, 2022 4:59 AM UTC
ist is not the '??' string but the 'Ö' character, that causes the error.
JennaKAtSafe
Forum|alt.badge.img+9
Hello @herfried​, could you share the log files/error message from FME Desktop? I would also suggest running the workspace on FME Desktop to see if the issue is to do with Desktop or Server.
  • Sep 27, 2022 5:40 AM UTC
Hello Jenna,
Seems to be an issue with 2022 Desktop and Server.
StringReplacer
evieatsafe
Forum|alt.badge.img+28
  • Sep 29, 2022 5:07 PM UTC
Hello Jenna,
StringReplacer
Hi @herfried​ unfortunately, I am unable to reproduce your issue with the StringReplacer. Could you share your workspace?
Alternatively, if you want to simply make the values empty strings I may suggest the AttributeManager to set and replace the values of those attributes to empty strings.
Hope this helps,
Evie
  • Oct 4, 2022 7:25 AM UTC
Workspace attached.
Workaround:
Input: 'Große ?? Gasse'
If I replace the 'ß' with 'SOME_STRING' than the replacement of '??' works fine.
bergstrand
Participant
Forum|alt.badge.img+4
  • Participant
  • Nov 9, 2022 8:28 AM UTC
I experience the same issue (build 22623). It is the "ß" character that causes the issue for me. As a workaround, I changed mode for the StringReplacer to "Replace Regular Expression".
@bergstrand​ to workaround this issue you can either use regex using text to replace: \\?\\? or switch to Case Sensitive = No
setld_solutions
Forum|alt.badge.img+8
FME Desktop 2022.2.4 - Seems like replacing ( ) { } ? * with nothing on a big string like webpage body is also having issues. Small strings like page title work fine.
I don't believe 2022.0 had this issue.
