String to URL (TextEncoder)
  • Aug 9, 2019 10:15 AM UTC
  • 103 views
I am using TextEncoder transformer to transform string into URL coded text. String is UTF-8 and have some Balkan letters (?, ž, ?, š) and this is where problems start.
For example word Kolašin TextEncoder translates into Kola%C3%85%C2%A1in but right way is Kola%C5%A1in. Is this some bug in TextEncoder or I am doing something wrong?
TextEncoder is set to encoding type URL(Percent encoding).
Maybe TextEncoder is not what I need at all so any suggest would be appreciated.
Best answer by david_r
I just tested with FME 2019.1, and the result seems correct:
š -> %C5%A1
Testing with FME 2018.1, however, I was able to reproduce the error. So the solution seems to be upgrading FME.
  • Aug 9, 2019 10:23 AM UTC
š -> %C5%A1
  • Aug 9, 2019 10:27 AM UTC
Thank you @david_r
I am using FME 2018.1.1.0 with home license. Will i lose my license if I update?
  • Aug 9, 2019 10:29 AM UTC
Thank you @david_r
I don't think so, no. Worst case you'll have to contact Safe support and explain the situation, but I would be surprised if that was necessary.
