String Searcher and Regular expression
  • Jan 28, 2019 10:51 PM UTC
  • 267 views
I'm not sure what words to use, again, to find my answer so I'm just going to ask.  I'm new to Regular Expressions, and not an FME wizard by any means
I need to, inside a loop,  take text that looks like this: (i'd like to avoid using blocking transformers if possible at this stage in my workbench)
OKC1D,790 [55559]|OKC1D, 791 [272]|OKC1D, 792|OKC1D, 796|XD, 4-6 [DEAD]
And make it look like this:
OKC1D,790 [5559]|OKC1D, 791 [272]|OKC1D, 792 [272]|OKC1D, 796 [272]|XD, 4-6 [DEAD]
With string replacers and searches I can get this:
OKC1D,790 [5559]|OKC1D, 791 [272]|OKC1D, 792|OKC1D, 796|
I'm able to select what's in the brackets with:
but I get 5559 and 272,  I need a way to select the last matched group, 272, there are cases where it may be more than 2 match groups but I think that If I can just select the last one it should work
https://rubular.com/r/r2TsFBPPy19hFO
Any regex wizards out there that may be able to help me, OR suggest a better way in FME to do what I want that will work inside a loop
Thank you
Best answer by takashi
If you set a list name (e.g. "_all") to the All Matches List Name parameter in the StringSearcher, '272' would be stored into the second element ("_all{1}.match") in the list.
  • Jan 28, 2019 11:03 PM UTC
