String Replace with Conditional Mapping
  • Oct 8, 2014 4:55 AM UTC
  • 5 replies
  • 100 views
hi experts
do you know if the string replacer can be used with conditional mapping to replace multiple strings  instead of using a few string replacers ?
i tried a few options but havent got it working
appreciate your help and suggestions
  • Oct 8, 2014 5:30 AM UTC
Could you please post some examples which describe what you need to do?
I'm guessing that the StringReplacer with regular expression, or the StringPairReplacer help you.
Takashi
gio
Forum|alt.badge.img+15
  • Oct 8, 2014 4:31 PM UTC
For multiples you can just use a creator and tcl regsub function.
gio
  • Oct 9, 2014 10:39 AM UTC
Or u can also use
 a creator with [string map {mappingpairs} string ]
Here is one to clean "bad" language....;)
..if this is what u meant.
  • Oct 9, 2014 11:45 AM UTC
@Gio, recently I have been exploring "<FME HOME>/transformers/fmesuite.fmx".
If you peek at the file, you can see that many transformers are implemented with Tcl commands, especially for string operations. The StringReplacer calls "regsub" and "string map"; the StringPairReplacer is a wrapper of "string map".
That's very interesting - the FME Internal :)
gio
  • Oct 9, 2014 1:44 PM UTC
Yes, i was aware of that for a long time.
In some post David, i think it was David even mentioned that FEM uses a lot of tcl.
The implementations are limited compared to what one can do by using creators.
In the string class transformers regexp use is very limited, u cant do forward (positive nor negative) lookups, u cant use switches etc.etc.
In attributeCreators u can use almost the full range of tcl (i even have one that executes a .exe from within a creator..lol).
Also you can nest them (seammingly) indefinitely.
nesting: @Evaluate([lsort -unique [split {"@Value(text_line_data)"} {}]])
Wich makes the AttributeCreeator extremely powerfull.
Prior to conditionla merging, conditionalmerging was already possible...by using tcl.
The hard or convoluted bit is the need to use the @Evaluate() at correct moments in a tcl in an attributecreator...
input: "Hello/DearFmeCommunity"
tcl1:
@Evaluate([regsub -all {([a-z])/*([A-Z])} "@Value(tststr)" {\\1@Evaluate(@Evaluate([regexp -all {[a-z](/+)[A-Z]} "@Value(tststr)" M m])==1?",":"" "")\\2}])
output:
Hello,Dear,Fme,Community
I have some that are truly unreadable...lol.
I made a couple of scripts in this forum showing this.
This is on the forum somewhere, about reading data out of a html fragment:
=[string range {@Value(html_txt)} [expr [lindex [lindex "@Value(tags_idxs)"  @Value(Ind)] 0] +1] [expr [lindex [lindex "@Value(tags_idxs)"  @Value(Ind)] 1]-1]]
Also tcl allows one to add missing FME transformers like
