String Removal
  • January 13, 2017
  • 11 replies
  • 464 views
Hi.
Im new to FME and this seems like a simple one.
I have an attribute called type and within it the following values
Floor:FLR1009
Slab:SLB2435
DOR-1000
WAL-2000
I want to remove the Floor: and the Slab:
Id rather use a string renamer if possible as the Floor: and Slab: will be constant.
Thanks
Chris.
Best answer by takashi
Yes, it seems to be a case where you can use regular expressions effectively and I agree that the StringSearcher would be a good starting point. If you have been familiar with regular expressions already, however, I think the StringReplacer would be an elegant solution to remove the leading "Floor:" or "Slab:" from each string value. The parameters would be:
  • Attributes: type
  • Text to Match: ^(Floor:|Slab:)?(.*)$
  • Replacement Text: \\2
  • Use Regular Expressions: yes
fmelizard
Forum|alt.badge.img+22
  • January 13, 2017
Hi @cfordigan. What is your question about string removal?
  • January 13, 2017
Hi.
Floor:FLR1009
Slab:SLB2435
DOR-1000
WAL-2000
Thanks
Chris.
fmelizard
  • January 14, 2017
I would suggest by starting checking out the StringSearcher. You could use two, one to remove Floor: and the other Slab:
Good luck!
  • January 14, 2017
  • Attributes: type
  • January 14, 2017
fantastic. It worked a dream!
Thanks so much.
  • January 16, 2017
Hi Again,
Can I ask, when I have a field like
Assembled Stair:
It replaces the Assembled, but not the Stair:
I have tried putting a . between the Assembled.Stair
To replace a full string and not one word, is there something I need to do perhaps?
Thanks again for your help
Chris
fmelizard
  • January 16, 2017
Hi Again,
Assembled Stair:
Chris
@cfordigan What transformer are you using? What have you entered for the transformer parameters? Thanks
  • January 16, 2017
Hi Natalie,
This is what Im using and all but the last part works perfectly.
The Assembled Stair: returns Stair: and I think because of the space, so Ive tried \\s. It works OK with the regex tester but I doesnt replace the string in FME.
Do you think this is the best way to remove this also? I may have up to 10 strings to replace.
^(Structural_Columns_UC-Univeral_Column:|Floor:|Railing:|Basic Wall:|Assembled\\sStair:)
Thanks for your help.
Chris
Forum|alt.badge.img+54
  • January 16, 2017
You may be better off using a string pair replacer here with the Replacement pairs syntax something like
"Assembled Stair:" "" Floor: "" Railing: ""
  • January 16, 2017
The regex ^(Structural_Columns_UC-Univeral_Column:|Floor:|Railing:|Basic Wall:|Assembled\\sStair:)?(.*)$ works for me in the String Replacer though
What version of FME are you using?
  • January 17, 2017
I guess that the requirement is to remove the leading part until the colon if the original string contains a colon. If so, the StringReplaceer with this regular expression could work too.
