String Function like StringSearcher RegExp
  • August 29, 2017
  • 8 replies
  • 82 views
i like to create a new Attribute in the AttributeManager using a string function like the StringSearchers FirstMatch.
Is there anything similar as string function?
e.g.:
Input: 102464, 12345, 123478
Regexp: ^\\d*
RegExp-Match: 102464
Desired output: 102464
Greetings Hendrik
  • August 29, 2017
Hi @hendrik, try this expression.
@ReplaceRegEx(@Value(source),^(\d*).*,\1)
  • August 29, 2017
Hi @takashi gerat it's working - but i don't understand.
^(\d*) matches the first digits
.* the rest of the string
\1 sould be the replacement sting
can you explain it to me?
  • August 29, 2017
^(\\d*) matches the first digits
\\1 sould be the replacement sting
That's right. \\1 indicates the substring that matches the first sub regex (i.e. the partial expression surrounded by round parens).
The function is equivalent to the StringReplacer (Mode: Replace Regular Expression).
  • August 29, 2017
Is there any documentation for this feature?
This is something i assumed to be part of the FindRegEx function. ;-)
Forum|alt.badge.img+53
  • August 29, 2017
FindRegEx returns the location of the match, not the match itself
  • August 29, 2017
See here to learn more about FME String Functions: Workbench String Functions
  • August 29, 2017
This is the standard help for the string functions the \\1 parameter isn't documented there. Maybe someone @safe will take care about that in the future.
  • August 29, 2017
\\1 (numbered backreference) is a standard in regular expressions, is not a standard of FME.
Regular-Expressions.Info > Replacement String Tutorial > Numbered Backreferences
The Help on the StringReplacer mentions it too.
