String (dash) replacement in AttributeManager using ReplaceString
  • Jul 19, 2023 2:20 PM UTC
  • 825 views
mzuer
Forum|alt.badge.img+5
Dear All,
in the attribute "id" I have strings that have the following format
411d8e4d-2de6-0f5b-e100-00000a4c0a0d
I would like to remove the dash in an AttributeManager (I know, I could do it with StringReplacer). I've tried the following formula :
@ReplaceString(@Value(id), "-", ""))
but it does not work (id remain unchanged), whereas the formula with FindString here below gives the expected result (8).
@FindString(@Value(id),"-")
 Why the FindString is working but not ReplaceString ? What am I doing wrong ?
I was also able to do it in the regular expression-way,
@ReplaceRegularExpression(@Value(id),"\-","")
 but I don't understand how ReplaceString works. Has anyone an explanation ?
Thanks in advance
Best answer by itsmatt
Interesting find. You can just put the "-" in your call without the quotes
@ReplaceString(@Value(id),-,"")
it looks like FME will also look for the " marks in the actual string as well. Funnily enough though you need to specify the "" in the output to indicate an empty string. A bit weird
itsmatt
Forum|alt.badge.img+48
  • Jul 19, 2023 2:28 PM UTC
itsmatt
  • Jul 19, 2023 2:32 PM UTC
Ahh indeed I also tried
@ReplaceString(@Value(id),"-","")
which worked - but if there is a <space> after the first comma it doesn't. I guess it's trying to find the <space> as well. Indeed if I do this, where the space is in the replace part:
@ReplaceString(@Value(_uuid),"-", "")
I end up with something like this:
c6a533b5 ""d76f ""4109 ""99c8 ""a59a66c9750c
mzuer
  • Jul 19, 2023 3:59 PM UTC
thanks a lot for the explanation !!! my question sounds really stupid now 😖 I am such a newbie... I'll never get used to the subtleties of FME...
