Hello,
I'm trying to convert a .DWG file containing height information from measuring elevation in the form of a point cloud, to a format like .OBJ or similar that I can read in non-AutoCad software. The file's been created professionally from a Leica land measurement device, and contains less than 200 points.
I'm getting this error message, probably because of text strings containing Swedish letters "åäöÅÄÖ", that generates an error when trying to write the file that seems to expect none such letters, see error text below
I'm attaching the file, also. Please, anyone that can help me out in this? I'm looking for conversion into a .OBJ, .3DS or similar file. All file destination types gives this error.
Thank you /Peter
File:
FME 2018.1.0.3 (20180926 - Build 18552 - macosx)
Creating reader for format: Autodesk AutoCAD DWG/DXF
Trying to find a DYNAMIC plugin for reader named `ACAD'
DYLD_LIBRARY_PATH is '/Library/FME/2018.1/plugins'
Loaded module 'ACAD' from file '/Library/FME/2018.1/plugins/acad.so'
FME API version of module 'ACAD' matches current internal version (3.8 20180604)
SOURCE_ACAD Reader: Using rich geometry.
AutoCAD Reader: Successfully opened the 'Release2013' AutoCAD file '/Users/svarteld/Desktop/A.dwg'
Merged 138 schema features read from 1 datasets into 138 resulting feature types
Opened mapping File /tmp/fme_FVr976.fme for output
The UTF-8 string `skärmtak` could not be converted to the encoding: US-ASCII
FME Session Duration: 1.0 seconds. (CPU: 0.4s user, 0.0s system)
END - ProcessID: 1106, peak process memory usage: 97668 kB, current process memory usage: 97668 kB
Program Terminating
Translation FAILED.
Warning: not all Stashed Objects that were registered were dropped before shutdown. This may cause instability
