Step-by-Step guide to convert IFC 4 Files to ESRI Geodatabase using FME Form
  • December 4, 2024
  • 0 replies
  • 232 views
spamula
Participant
Dear FME Community,
I have a FME Form and also ArcGIS Pro license. I am new to IFC format and also new to FME Workbench. I want to view and work with the IFC Files in ArcGIS Pro and later publish it as a WebScene in ArcGIS Online.
I do not have Data Interoperability Extension License for ArcGIS Pro.
To achieve this i need to clarify below questions :
Using FME 2023.2 and ArcGIS Pro 3.4.0
  1. How to convert IFC files to ESRI Geodatabase using Workbench ?
  2. Should i change the Coordinate system (Gauß-Krüger) of IFC files in order to view and work with the files in ESRI Geodatabase (ETRS89.UTM-32N) ?
  3. Which coordinate system should the output files have in order to work in ArcGIS Pro ?
Please find the screenshots for more information.
IFC Files with Coord.System
Writer Format with Coord.System
A detailed solution with working steps would be helpful. Thank you.
