STEP by STEP guidance to obtain desired results to be filled out in EXCEL
  • Mar 22, 2022 10:59 AM UTC
  • 34 views
magi
PROBLEM 1
if in column TYP the value is PL
than do nothing (keep the cell G1, H1, I1 empty)
PROBLEM 2
if in column TYP the value is PE
than calculate value in "x1 in (m)"
check condition "F is W" or "F is E" or F is S"
here the condition is "F is W" so
fill in default value from "Y in (m)" to "y1 in (mm)" and from "Z in (m)" to "z1 in (m)"
FORMULA to calculate/obtain value in "x1 in (m)" i.e. 1960.85
from the DIM in (mm) always select the first value before "x" for i.e. 600
and convert it from millimeter (mm) into meter (m) i.e. 600/1000 = 0.6
now add the result i.e. "X in (m)" + "0.6"
PROBLEM 3
if in column TYP the value is HO
than calculate value in "y1 in (m)"
here the condition is "F is E" so
fill in default value from "X in (m)" to "x1 in (mm)" and from "Z in (m)" to "z1 in (m)"
FORMULA to calculate/ obtain value in "y1 in (m)" i.e. 5988.27
from the DIM in (mm) always select the first value before "x" for i.e. 500
and convert it from millimeter (mm) into meter (m) i.e. 500/1000 = 0.5
now add the result i.e. "Y in (m)" - " 0.5"
********************************************Workbench Excel
@magi​ From a quick glance through the problems you're trying to solve I think the AttributeCreator Conditional Value... is worth looking at
