StatisticsCalculator - results without geometries?
  • Aug 24, 2018 9:14 AM UTC
  • 201 views
rob_z
I use the StatisticsCalculator and group features by attributes. The result features do not have a geometry anymore.
I cant see see why this happens - anyone having a tipp?
Rob
Forum|alt.badge.img+54
  • Aug 24, 2018 9:30 AM UTC
Depending on what statistics you are collecting you may be able to use an aggregator instead.
Otherwise, prior to the statistics calculator you can extract the geometry to an attribute, ensure this is one of your group by attributes and rebuild with the geometry replacer afterwards.
stalknecht
Forum|alt.badge.img+22
  • Aug 24, 2018 9:31 AM UTC
Probably you use the Summary port. If you want the geometries then you have to use an Aggregator (with the same group by) and a FeatureJoiner to add the summary of the StatiscticsCalculator to these geometries. Good luck!
