Statistic report on Rolling 12 Months
  • November 27, 2019
  • 26 views
Dear All ,
How to do statistic report on on rolling 12 month basis , e.g on 1/1/2019 , we need the sum and count from 1/1/2018 till 1/1/2019 and so on .
Thanks ,
Forum|alt.badge.img+46
  • November 27, 2019
I would
  1. Create a new attribute with the date converted to a month/year format only, e.g. 1/2018.
  2. Ensure that your data is sorted in date order
  3. Send to the statistics calculator with a group by on the newly created month year attribute
  4. Use the cumulative output (be aware that there may be a workaround required to get round an issue with the statistics calculator)
https://knowledge.safe.com/questions/102959/incorrect-results-from-statisticscalculators-cumul.html
  • November 27, 2019
Thanks @ebygomm for the support but it is not adding the previous month . the output should be as rolling12month output
  • November 27, 2019
I misread, I think you don't need the group by at all in that case, and then just keep the output for the first of each month
