SSL Certificate Verify Failed
  • May 7, 2020 4:30 PM UTC
  • 448 views
crowleyb
Forum|alt.badge.img+4
Hello:
I created a workspace with a python caller to access a Zoom api endpoint. I copied the same python code from Zoom's code generator and the code runs fine. I copy the same code into a python caller and I receive the following errors. I have no proxy I am going through. I have very limited python experience. Any help would be appreciated.
Errors:
Python Exception <SSLCertVerificationError>: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate in certificate chain (_ssl.c:1076)
Error executing string `import<space>http.client<lf>import<space>fme<lf>import<space>fmeobjects<lf>#<space>Template...
Factory proxy not initialized
PythonCaller (PythonFactory): PythonFactory failed to process feature
Code:
import http.client
import fme
import fmeobjects
# Template Function interface:
# When using this function, make sure its name is set as the value of
# the 'Class or Function to Process Features' transformer parameter
def processFeature(feature):
pass
# Template Class Interface:
# When using this class, make sure its name is set as the value of
class FeatureProcessor(object):
def __init__(self):
pass
def input(self,feature):
self.pyoutput(feature)
def close(self):
pass
conn = http.client.HTTPSConnection("api.zoom.us")
headers = { 'authorization' : "Bearer [some value]" }
conn.request("GET", "/v2/users?page_number=1&page_size=30&status=active", headers=headers)
res = conn.getresponse()
data = res.read()
print(data.decode("utf-8"))
  • May 7, 2020 4:39 PM UTC
This would be better suited for either a Python or a Zoom API forum as it has very little to do with FME, but try replacing this line:
with this (all on one line):
conn = http.client.HTTPSConnection("api.zoom.us", context = ssl._create_unverified_context())
You'll probably need to add "import ssl" at the top of the script as well.
See: https://stackoverflow.com/a/50949266
crowleyb
  • May 7, 2020 5:37 PM UTC
Thank you! I appreciate the assistance. I'm very new to python so I wasn't sure if the issue was FME given I'm using an PythonCaller in my workspace to run this. A thousand pardons for posting this in an FME forum.
  • May 8, 2020 6:55 AM UTC
No worries. Does this mean that the modification worked?
crowleyb
  • May 8, 2020 10:15 AM UTC
Yes. the modification worked
