SQLExecutor on MS SQL Server 2008 R2
  • May 14, 2014
  • 5 replies
  • 72 views
francis_m
Forum|alt.badge.img+9
HI,
I need to make some simple sql query (like select COUNT(*)) on ArcSDE Table stored on a MS SQL server.
When I use the SQLExecutor, I can't connect to my DB.  How to connect.
I can read with a reader, I can write with a writer, but I need to perform some simple SQL query.
How to do this.
Server ?
Database ?
Do I have to create an OLDB connection on my windows OS ?
Thanks!
francis_m
  • May 14, 2014
See the error FME return
MS SQL Server Reader: Connection failed.  Connection string `Provider=SQLOLEDB;Data Source=Q1541BE;Initial Catalog=gs0599_i5;User ID=[MY_USER];Password=[MY PASSWORD]'. Provider error `(-2147467259) [DBNETLIB][ConnectionOpen (Connect()).]Ce serveur SQL n'existe pas ou son accès est refusé.'
Failed to open reader
  • May 15, 2014
what are the (working) connection parameters you're using to connect with SDE? And which parameters have you tried for the MS SQL Server reader?
David
francis_m
  • May 15, 2014
For a GEODATABASE_SDE reader / writer  I work with those parameters :
Server : s.o. (mean nothing but have to write something)
Username : my_user
Password : my_password
Instance Name : sde:sqlserver:q1541VIP,1456
Database : gs0599_i5
If I want to use SQLExecutor I need those parameters :
The value entered does not work...
Format : Microsoft SQL Server Non-spatial
Dataset : gs0599_i5
Server : q1541VIP,1456
Username : my_user
  • May 15, 2014
when I look at the error message that you posted above and compare it with what you posted just now, I see a discrepancy between the server names:
Log server name: Q1541BE
SQLExecutor server: q1541VIP
Could this be the cause?
David
francis_m
  • May 15, 2014
Hi!
Yes, thats depends on where I run my FME.  I need to connect BE (for Backend) on another machine, but I need to use VIP on my computer, but it's the same.
