SQLExecutor - Keep order when populating the attribute list for the query
  • Jun 27, 2017 8:15 AM UTC
  • 12 replies
  • 133 views
mikel
Is it possible to keep the order of the query fields when you get the attributes using 'Populate from SQL Query...'? I use it very often and the attributes are ordered alphabetically instead of the order in the query.
Thank you
Best answer by david_r
You'll have to order the attributes manually after importing them, unfortunately.
jneujens
  • Jun 27, 2017 8:19 AM UTC
Isn't it possible to set the order of the attributes in the 'attributes to expose' settings?
  • Jun 27, 2017 8:27 AM UTC
Forum|alt.badge.img+54
  • Jun 27, 2017 8:32 AM UTC
If you suggest it as an idea, I'd vote for it
  • Jun 27, 2017 8:33 AM UTC
Agreed. I'd rather the database order was preserved and having an optional "sort" button.
mikel
  • Jun 27, 2017 10:24 AM UTC
No, it is not possible.
mikel
  • Jun 27, 2017 10:26 AM UTC
There was already a idea for that:
https://knowledge.safe.com/idea/22950/order-of-columnsattributes-set-in-sql-is-ignored-b.html
mark2atsafe
Forum|alt.badge.img+59
fwiw (they may not count it) I voted for this!
  • Jun 27, 2017 4:13 PM UTC
It wouldn't let me vote for this so I'm guessing I already voted at some point
If you have DDL access create a view in your DB and import that.
  • Nov 28, 2018 11:06 AM UTC
I have the same problem in FME 2018. A large list of attributes generated from an SQL query is sorted alphabetically in "Attributes to expose".
Is the only solution still to sort them manually?
xiaomengatsafe
Forum|alt.badge.img+11
Hi @stihe, Looking at the status of this related Idea, https://knowledge.safe.com/idea/22950/order-of-columnsattributes-set-in-sql-is-ignored-b.html, unfortunately I believe currently manually reordering them is still the only option. Please vote for the idea, and add your comment to give that idea more momentum. Thank you very much!
  • Apr 9, 2019 3:43 PM UTC
An other somewhat hacky option is to use other software, like toad, to extract the first record of your data to csv, then copy the header row and paste it into the attributes to expose.
While it takes a few steps if saves having reorder everything, especially when you have a lot of fields.
Note when you first add the transformer you can't manually edit the attributes, so just enter anything from the ... then you can paste in you list of fields on the main transformer screen.
Hope this helps
