SQLExecutor fails with BETWEEN statement
  • Dec 23, 2025 11:15 AM UTC
  • 117 views
kateaew
Forum|alt.badge.img+11
FME Form 2025.1
SQL Query in SQLExecutor:
SELECT * FROM table_name WHERE ID BETWEEN $(polystart) AND $(polyend);
Oracle table
Works fine in DBeaver with actual ID numbers
Fails in FME with actual ID numbers
Fails in FME with User Parameters for the numbers
Error Message:
Execution of statement `SELECT * FROM table_name WHERE ID BETWEEN 35480 AND 35484;' did not succeed; error was `ORA-00933: SQL command not properly ended'.
Does FME just hate a BETWEEN statement?
Going mad trying to figure out where I am going wrong 😂
Best answer by kateaew
I added FME_SQL_DELIMITER ; and removed the last semi colon of the statement and it has worked
For anyone who comes across something similar in the future
kateaew
  • Dec 23, 2025 11:29 AM UTC
geomancer
Forum|alt.badge.img+71
  • Dec 23, 2025 12:47 PM UTC
Just removing the semicolon should be enough, in this case there is no need to add FME_SQL_DELIMITER (tested with FME 2023.1.1 / Oracle 19).
