SQLExecutor - can a user parameter serve as the Initiator?
  • Jul 27, 2021 1:28 PM UTC
  • 137 views
plynn
Forum|alt.badge.img+10
I am not getting the results that I expected. I believe it may be because I do not have anything connected to the 'Initiator' for the SQLExecutor transformer. What I was trying to do, was to execute the SQL statement and if no results were returned then proceed with the workspace. If records are returned, then send to the Writer. This sql statement should return 1 row.
Best answer by ebygomm
You can just put a creator in front of your sqlexecutor, this will then execute the sql statement once, using your referenced parameter
Forum|alt.badge.img+54
  • Jul 27, 2021 3:44 PM UTC
plynn
  • Jul 27, 2021 6:40 PM UTC
Thanks, that did it.
