SQLCreator errors out even though results are returned
  • August 12, 2024
  • 0 replies
  • 29 views
camerond
Observer
Hello,
I have just upgraded to FME 2024.1 (was originally using FME 2022) and when running an SQLCreator using ODBC3.x I get an error, this was working just fine when using FME 2022.
What’s strange is that even though I receive an error, all expected features are semi-cached and observable in the translation view as shown in the picture, the problem is that I can’t continue to run the following transformers as FME is taking it that the SQLCreator failed.
Does anyone have any advice on how to get around this? My SQL code is fairly simple, just pinging an Azure database and doing some basic joins (the code also works fine when running on Azure Data Studio). Thank you!
