SQL To Execute After Translation syntax problems
  • Apr 29, 2013 6:14 AM UTC
  • 9 replies
  • 93 views
Hi all,
I'm trying to run a SQL statement after a translation to execute a stored procedure.
This SQL executes correctly -> EXECUTE EDIGISDB.data_extracts.log_data_extract ('FLUOR') in SQL*Plus however it's erroring in FME with the following message.
2013-04-29 15:29:35| 1.0| 0.0|ERROR |BADNEWS: Execution of statement `EXECUTE EDIGISDB.data_extracts.log_data_extract ('FLUOR')' did not succeed; error was `ORA-00900: invalid SQL statement
Any and all assistance is greatly appreciated. We've been trying different syntax none of which seems to work.
Thanks
Micahel Drover
  • Apr 29, 2013 7:23 AM UTC
try this syntax:
begin
EDIGISDB.data_extracts.log_data_extract ('FLUOR');
end;
You will probably get some warning in the log about the semicolons, but you can ignore those.
David
  • Apr 29, 2013 1:34 PM UTC
Would using
FME_SQL_DELIMITER ;
on the first line not remove the warnings?
  • Apr 29, 2013 2:02 PM UTC
Hi Mark,
yes, in this case it would replace the warnings with errors, since FME would then execute each part separated by a semicolon separately, which would confuse Oracle a lot :-)
On the other hand, perhaps it could be worthwhile to also try without the begin/end transaction clause. If it works, no semicolons would be needed at all.
David
sam-tizz
  • Apr 30, 2013 3:45 AM UTC
I had followed similar approach what david has suggested. It works fine
sam
  • Apr 30, 2013 4:39 AM UTC
Thanks for the replies guys but stil no success with this.
I've tried David R's suggestion of removing the ; and begin/end component and still no joy. I've also tries the follwoing
FME_SQL_DELIMITER ;
begin
end;
With the same result...man this isstating to test me!
Thanks
Michael
  • Apr 30, 2013 7:14 AM UTC
first of all, do not use "FME_SQL_DELIMITER" at all, it is not applicable in this scenario.
Did you try my original suggestion with the begin/end clause? It should work.
If it doesn't, is the error message still the same? Can you post your log file somewhere?
David
  • Apr 30, 2013 10:51 PM UTC
Hi David.
I did try your initial suggestion as well as including the DELIMETER statement.
|t the moment I;m not having success with
begin
end;
The part error log I'm getting is below.
2013-05-01 07:58:15| 0.9| 0.0|WARN |Semicolons detected in SQL. May need to use FME_SQL_DELIMITER keyword to specify a delimiter. SQL is: 'begin EDIGISDB.data_extracts.log_data_extract ('FLUOR'); end;'
2013-05-01 07:58:15| 0.9| 0.0|ERROR |BADNEWS: Execution of statement `begin EDIGISDB.data_extracts.log_data_extract ('FLUOR'); end;' did not succeed; error was `ORA-06550: line 1, column 7:
PLS-00201: identifier 'EDIGISDB.DATA_EXTRACTS' must be declared
PL/SQL: Statement ignored
'. (serverType=`ORACLE8i', serverName=`gisprod', userName=`miread', password=`***', dbname=`') (.\\stfdb.cpp:245)
2013-05-01 07:58:16| 0.9| 0.0|WARN |Semicolons detected in SQL. May need to use FME_SQL_DELIMITER keyword to specify a delimiter. SQL is: 'begin EDIGISDB.data_extracts.log_data_extract ('FLUOR'); end;'
2013-05-01 07:58:16| 0.9| 0.0|ERROR |BADNEWS: Execution of statement `begin EDIGISDB.data_extracts.log_data_extract ('FLUOR'); end;' did not succeed; error was `ORA-06550: line 1, column 7:
2013-05-01 07:58:16| 0.9| 0.0|INFORM|Translation was SUCCESSFUL with 4 warning(s) (0 feature(s)/0 coordinate(s) output)
2013-05-01 07:58:16| 0.9| 0.0|INFORM|FME Session Duration: 21.8 seconds. (CPU: 0.2s user, 0.3s system)
2013-05-01 07:58:16| 0.9| 0.0|INFORM|END - ProcessID: 6376, peak process memory usage: 33960 kB, current process memory usage: 33660 kB.
Translation SUCCEEDED.
When refreshing the linked table in Mapinfo I'm not seeing the update that I'm expecting.
Appreciate your help David.
Thanks
Michael
sam-tizz
  • May 1, 2013 10:42 AM UTC
Hi
The error which you have reported is actually generated from Oracle and not from FME. FME has infact executed the stored procedure
Please test your stored procedure
ORA-06550 is generally PLSQL compilation error
Sam
  • May 2, 2013 4:33 AM UTC
Thanks David R. Your syntax was correct however there were some access privileges that needed to be allowed for our read user. I've had our Oracle guru take a look at it for me and he has sorted it. The
 was the giveaway for him.
It's all up and running.
Thanks again.
Michael
