SQL grouping issue
  • Mar 9, 2018 11:14 PM UTC
  • 57 views
kartemann
I'm attempting the below query in an SQL Creator. I get a "malformed statement" error. How should I format this to run? It works outside of FME... Thanks!
SELECT
field1,
field2, field3  FROM table1 INNER JOIN table2 ON table1.ID = table2.ID  GROUP BY field1,field2
austinh
Forum|alt.badge.img+4
  • Mar 9, 2018 11:38 PM UTC
try calling out your fields with the table name Such as “table2.field1” throughout your statement.
  • Mar 10, 2018 1:32 AM UTC
Hi @adamradel, the SQL syntax and error handlings may be different depending on database engines. I found general issues as below, but in the actual database format you are using, these may not cause any error or there could also be other issues.
  • "field3" cannot be select here since the GROUP BY clause doesn't contain it. If you intend to aggregate the records grouping by all the three columns - field1, field2, and field3, add "field3" to the GROUP BY clause. Or, if you intend to apply an aggregate function (e.g. SUM, MIN, MAX, ... etc.) to "field3", use the function correctly.
  • If one of field1, field2, and field3 is common to the two tables, the field name should be qualified by an appropriate table name to which the field belongs, as @austinh suggested.
