SQL Executor Update Statement issue
  • Sep 13, 2019 10:54 AM UTC
  • 187 views
Hi, I am trying to run an SQLExecutor transformer with the following SQL:
FME_SQL_DELIMITER ;
UPDATE "PROJECTS"
SET "TBL_REFRESHDATE" = '16-JAN-2020',
    "TBL_REFRESHUSER" = @Value(REFRESHUSER);
COMMIT;
When I run this I get the following error message
|ERROR |An error occurred while accessing a table result for feature type `'; message was `Execution of statement `UPDATE "PROJECTS"
    "TBL_REFRESHUSER" = TEST' did not succeed; error was `ORA-00904: "TEST": invalid identifier'.
Where TEST is the value which is currently in the TBL_REFRESHUSER column in the table, not the value which I am trying to populate the column with (ie: 'test_user').
However, when I run the following SQL, replacing @Value(REFRESHUSER) with a hard coded string of 'test_user', the script works:
FME_SQL_DELIMITER ;
UPDATE "PROJECTS"
    "TBL_REFRESHUSER" = 'test_user';
COMMIT;
What do I need to do to get the attribute values to be read properly inside the SQLExecutor?  The REFRESHUSER attribute is definitely a string so I don't know why it is not being read in.
I am using FME Desktop 2019.1
Thanks,
  • Sep 13, 2019 11:08 AM UTC
You need to put single quotes around your string, FME won't do it for you. Example:
"TBL_REFRESHUSER" = '@Value(REFRESHUSER)'
  • Sep 13, 2019 1:37 PM UTC
Thanks that's perfect!
