SQL Executor for creating unique IDs
I am using the SQL Executor transformer followed by Counter transformer to create unique IDs for new features that I am adding to an existing Oracle table.
The SQL Executor transformer fetches the maximum ID number in the existing table, and then the Counter transformer adds 1 to it.
However when I run the workbench the new features in the Oracle table have a geometry of NULL and in the FME log it says "Spatial Column 'GEOM' is NULL. Geometry will be updated to NULL."
I am wondering if it is something to do with the settings in the "combine attributes" or "combine geometry" options in the SQL Transformer. But I have tried a number of combinations of settings and cannot get it to work.  I only have the "Result" section of the SQL Executor transformer linked to the "Counter" if this is also part of the problem...
Does anyone have any ideas?
  • October 6, 2014
I suspect you're on the right track about the "combine" settings. It should work if you set it up like this:
Tip: consider using an oracle sequence rather than the SELECT MAX(...) and Counter idiom. It is more robust and possibly also quicker.
David
  • October 6, 2014
Hi David,
Thanks for your reply.  Did you post a screen grab into your response with the set-up? If so, I can't see it due to browser issues.  Are you able to describe the set-up in words?
Thanks,
  • October 6, 2014
try passing your features through one or two GeometryValidators.
David
  • October 8, 2014
Hi David,
I tried that but it came up with no errors.  I ended up just using a Sequencer and Trigger in Oracle instead..  Still not sure what was wrong with the FME workbench though. Thanks,
