SQL Executer Line between Point and Line
  • Jan 15, 2019 10:13 AM UTC
  • 62 views
I have a SQLite database with point and line geometries. I want to create a line between the points and the line objects. This line should be the shortest path and the sounding line (90 degres) on the existing line.
How can I manage this with a SQL Statement?
I want to use the spatial functions from SQLite
Thank you and best regards
Forum|alt.badge.img+63
Is there any reason why you specifically want to use the SQLExecutor and the SQLite spatial functions? This can also be solved by using the NeighborFinder in FME.
  • Jan 15, 2019 2:21 PM UTC
I use FME to find the best way for connecting the points with the line. But the final calculation should be done in a SQLite database. So I can´t use all of the fme functions.
Ok, but why? Does that give a different result than when you're doing it in FME?
Either way, I think what you can try is writing the data to the SQLite database using a FeatureWriter and then afterwards use the SQLExecutor to fire the SQL query to the database.
