SQL CREATOR, JIRA API and HTTP CALLER
  • February 24, 2020
  • 55 views
armando_amador
Forum|alt.badge.img+4
I have a Maria DB and a JIRA platform, I would like to use the DB to create new issues there through the JIRA API, how can I integrate all of them?
I have already made the regular CRUD operations to the JIRA platform through the API using the HTTP Caller, but, how can I properly use the SQL Creator to use that data?
  • February 25, 2020
Could you perhaps try and narrow down your question a little? It's fairly broad with not too much detail, so it's not an easy one to answer.
armando_amador
  • February 25, 2020
Yes, I apologize for the very brief details:
I'm trying to use the data from certain tables contained in a non-spatial DB to create new issues in the JIRA platform through the use of its API which I have properly connected with HTTP Caller. As a sample, I would like to get some values from a MYSQL table called "Label" to this JSON sintaxis:
"fields": {
"project":
"key": "TEST"
"summary": "REST ye merry gentlemen.",
"description": "Creating of an issue using project keys and issue type names using the REST API",
"label" : "examplelabelnumber1",
"issuetype": {
"name": "Bug"
but I'm not quite sure how to call the value to this sintaxis.
  • February 25, 2020
So if I'm understanding you correctly, you want to read some MYSQL table and use the contents to populate a JSON document. Obviously this will depend on if it's a single MYSQL table or multiple tables that you have to join, but first thing to try is something like the following workflow:
<MYSQL reader> -- <JSONTemplater> -- <HTTPCaller>
There's a pretty good article about using FME to write JSON, see:
https://knowledge.safe.com/articles/44293/json-writing-overview.html
In particular, you may want to look at this article that showcases the JSONTemplater:
https://knowledge.safe.com/articles/44294/json-writing-with-jsontemplater.html
And the JSONTemplater documentation:
http://docs.safe.com/fme/2019.0/html/FME_Desktop_Documentation/FME_Transformers/Transformers/jsontemplater.htm
