Best Answer
SQL Connection Problem
  • December 6, 2012
  • 39 views
travis
I have an automated nightly process that runs and outputs several tables to SQL Server 2008.  This week we have had intermitten issues with connecting to SQL server.  One night it failed and the next it worke and then again it failed.  It is giving me an warning message of:
MS SQL Server: Connection not properly cleaned up, please contact support@safe.com. Connection key '1_|_3_|_TABLENAME_|_DATABASENAME_|_<unused>_|
I am looking for any insight of what might be causing this.  Is it an FME issue or a SQL DB issue.  I am running FME 2012 SP2 Build 12235 WIN32.
Thanks
Travis
Best answer by sigtill
Usually when it says Connect support@safe.com it is a difficult issue and atleast the entire logfile is needed.
If possible, I would suggest you try the FME2012 SP4 and see if that has the same issue. It seems issues with databases are quite regularly fixed.
If you cant upload the logfile, then I would suggest to contact Safe directly: http://fmepedia.safe.com/knowledgeSubmitCase?
sigtill
Forum|alt.badge.img+25
  • December 6, 2012
