Splitting Row
  • Jan 14, 2021 1:43 PM UTC
  • 139 views
Is there a easy way to do that in FME?
Splitting_rowThats how i did it:
Splitting_row2now i wonder if there is a easier solution.
Best answer by debbiatsafe
Hi @fluusha​ ,
Another option in restructuring your data would be to use a modification of the second example of this transpose table article. The attached workspace does assume any attribute names without a number suffix is part of the same transposed row.
splitRow
alexlynch3450
Forum|alt.badge.img+16
Here you go bub. Its quite the Band-Aid approach, but easier than previous solution.
debbiatsafe
Forum|alt.badge.img+24
  • Jan 16, 2021 12:26 AM UTC
Hi @fluusha​ ,
splitRow
  • Jan 20, 2021 9:08 AM UTC
Hi @fluusha​ ,
splitRow
Can you tell me how you created the Attributes in the Creator?
I cant find a way to do this i always put a attributemanager behind it to create the attributes.
Creator
debbiatsafe
Creator
Hi @fluusha​
Transformers have an option to add attributes if you right-click on the output port.
creatorAddAttributes
