Hi, Im trying to split a large dataset of lines (~1.2m records) by an almost equally large dataset of polygon boudaries (~900k records). I have tried Line Over Area Overlay, but no luck there. I tried creating points at the intersections of the lines and polygons boundaries, and executing point on line overlay, but I came up empty there as well. Has any one run into this problem before, and what conclusion/solution did you come to?
