Splitting Linear Referencing Segment and assign a Value to First Segment
  • July 19, 2017
  • 108 views
I am new to FME, and I am trying to set up a workflow to transform some LRS segment feature data using the following rule: Assume that each feature segment has route identifier, begin and end measure, and a "split key" which is a value that indicates a percentage of the total segment length that I should split the event in TWO. I think this can be done with the Clipper transformer.
In addition however, I have another requirement where when I split the event into 2, I need to add a new value to the first segment only. This is what is tripping me up. After splitting the segment, how do I identify the first of the 2 splits and add the value. If my explanation is not clear enough, see the following example data
INPUT: Given the following example Event Segments: ROUTE_IDBEGIN_MEASUREEND_MEASURESPLIT_KEYR1 0520%R23950%R2912100%
OUTPUT: ROUTE_IDBEGIN_MEASUREEND_MEASURE
NEW_ATTR
R101AR115nullR236AR2612nullR2912A Note that in the last segment, a split of 100% yields the same segment so there is only one segment in the resulting split list. Anyway, I am open to suggestions.
Thanks, Tom
  • July 19, 2017
I figured out how to do this. Just use the cloner and read the "Copy Number Attribute" to decide which new Feature to add the NEW_ATTR value to. Use the Snipper transformer to resize segments.
  • July 19, 2017
Alternatively, you can send the feature to a Snipper at first, then add NEW_ATTR = A to the Output feature, and add NEW_ATTR = <null> to the Remnants feature.
Snipper Parameters
  • Snipping Mode: Distance (Percentage)
  • Starting Location: 0
  • Ending Location: SPLIT_KEY
  • July 20, 2017
Snipper Parameters
Thanks, didn't see that in the Snipper...another handy trick.
