Splitting ArcGis Annotation with multiple words
  • Jan 24, 2018 11:48 AM UTC
  • 91 views
ciarab
Forum|alt.badge.img+10
Does anyone think it is possible to take annotation that is a single feature but contains multiple words (of different rotations) and create a new feature for every word with a new textpoint geometry and rotation for that word?
For example the following is a single piece of text that is curved to follow the road.
  • I want to separate this into two objects
  • New location for the second word
  • New rotation of the second word
I haven't attempted this yet but wondering if its something that could possibly be achieved in FME
Thanks
gio
Forum|alt.badge.img+15
  • Jan 24, 2018 4:25 PM UTC
Well, best you can do using the annotation layer is to save the layer to a gdb.
That will "Freeze" it to the placement in the viewing scale.
You can read the layer from the gdb with fme.
That will give you polygons or aggregate polygon, depending on placement. Including a lot of info. like font etc. (alas no height though and no insertion points)
Your example would yield a 2 polygon aggregate. Making it easy to separate them by deaggregaton.
How are you going to give the second bit a new location though.. do you intend to insert a reference point/or line?
In that case you can use a affiner to move the object. The insertion point of the second word is a problem because there is no insertion point stored in the annotation layer.
You could however try to create centerlines and try to filter begin and end of the geometry. Then filter for the resulting corners.
This depends hugely on the way the text "flows".
Full control of placement is better done by having road centerlines, and use segmenting and snipping to create placement locations at will. Of course one would have to have centerlines..
There is tool to convert feature to outline with which you could turn annotation to graphic, but it is under advanced license and has no anti aliasing..
Also you might try adding more spaces...though that's like yuck manual labour.
ciarab
  • Jan 24, 2018 10:49 PM UTC
Thanks @gio we were planning on saving the layer to a gdb to freeze the text placement but yes finding the insertion point and angle of the second word that I imagine is difficult. We haven't played around with it yet as we are trialing a few options. Just trying to gauge whether this is a feasible task. Will let you know if we have any success!
We have access to the tool you mentioned to turn anno to graphic so will take a look at it too thanks.
