Splitting an address
  • January 29, 2017
  • 104 views
gisgeek
Forum|alt.badge.img+9
Hi I am trying to use a regular expression to split an address. It sounds relatively simple but I keep getting caught out on some of the address inputs:
Here are the scenarios. So I want to split the address after the - but in these scenarios I might have a range like the second one or there might be a space after the name or there might not.
On Gas Limited- 37 Hunua Road
Ixom Operations Pty Limited - 135-147 Waterloo Road
Best answer by jeroenstiers
Hi @gisgeek
Great you figured out the answer! However I would like to suggest to improvements depending on the result you want. (1) I am assuming that you don't want the hyphen to be part of your address and (2) that in some occasions, the first part of the string might contain a hyphen to.
1/ You can make use of a so called 'positive lookbehind' to select everything following a specific regex. In this case you could select everything which is following a hyphen. Using this method, you will remove the hyphen and leading spaces from the result.
Example:
input: On Gas Limited- 37 Hunua Road
regex: (?<=-).*
result: ' 37 Hunua Road'
2/ You might want to make the regex a bit more strict to allow hyphens in the first part of the string. If you are certain that the address always starts with a numeric value, use this information
input: On Gas - Limited - 115 - 116 Hunua Road
regex: (?<=-)\\s*\\d+.*
result: ' 115 - 116 Hunua Road'
Try the regex here
gisgeek
  • January 29, 2017
Oh yaye I think I worked it out (-)\\s seems to work
Forum|alt.badge.img+7
  • January 30, 2017
Hi @gisgeek
Example:
regex: (?<=-).*
Try the regex here
