spliting of polygon for polyline creation
  • October 24, 2018
  • 7 replies
  • 47 views
gis2020
Forum|alt.badge.img+5
Hi All,
I have polygon layer for road feature which is generated from the raster layer . each polygon is form by multiple road polygons Now i would like split each polygon to it's sub component i.e. individual roads layer.
can somebody help me with this ?
larsatomkeere
Forum|alt.badge.img+9
  • October 24, 2018
Looking at the title of your issue, you might consider using a CenterLineReplacer. Often it will give you some shorter lines at the end as well, but those can be cleaned afterwards.
gis2020
  • October 24, 2018
@larsatomkeere i tired to use that but it's not working with this. it generates te line with multiple small lines connected to main central line.
lars_de_vries
Forum|alt.badge.img+10
If you only want to keep the long lines and continue from there, you could use a deaggregator to extract the smaller lines and subsequent use a Tester or a TestFilter to filter out the smaller lines based on their @Length() value.
mark2atsafe
Forum|alt.badge.img+59
  • October 24, 2018
What version of FME are you using? There was a recent update to the CenterLineReplacer that I found very useful. I can't recall if it was 2018 or 2019 though - ah, I checked and it's 2019 (see this question: https://knowledge.safe.com/questions/31926/cleaning-gps-line-work.html). It does seem like it would solve the issue of the multiple small lines though.
gis2020
  • October 25, 2018
@Mark2AtSafe i am using FME 2018.1 for this conversion
gis2020
  • October 25, 2018
@lars_de_vries i tested with this using length option but it removes the line which are needed to create the central line also.
mark2atsafe
  • October 25, 2018
Right, I think you would need to use the 2019 beta to get the ideal solution with the CenterLineReplacer. In 2018 all I can really think of is to use a Bufferer with a negative value to make your polygons a bit smaller. Then the 2018 CenterLineReplacer might create the centre line without so many small, side lines.
